Old July 5th 2004, 20:09
Final draft of new club rules
i finally got around to incorporating the feedback from the first draft of rules and think i have a final draft. need everyone to re-read and see if there is anything ugly in there. i made some allowances for T2's on suspension upgrades, assigned some point variables (defined by the gruppe officers based on physical or photographic inspection but will only be used in select cases and assumed zero points in most cases) for several categories to cover "quality of workmanship" concerns (i.e. an engine conversion that may or may not meet minimum point requirements for a class and to ensure safe and quality work), gave the classes some names (open for feedback), added lap belts as mandatory minimum, and addressed areas around benefits and such.
i still have to do some work to actually get t-shirts, workshirts, etc lined up (haven't even started, but didn't want it to be a hold up for the rules anymore) and will cover whatever cost the club can't cover. it will just take members to make it up.
sorry for the length, but here we go...
VKG Gruppe Rules, Benefits and Car Requirements
Gruppe Rules and Benefits
We are predominantly a South Eastern US Gruppe, but we are open to anyone, anywhere that would like to join. Membership in the VKG is structured as membership for the person and a separate membership for your car as a VKG car. The breakdown is as follows:
VKG Member: Basic membership in the VKG is open to all. You may have a German Look car complete, under construction, in the planning stages, or no car at all and just want to hang out with GL junkies and you can be a VKG’er. This allows for anyone to be part of the gruppe. Any and all are welcome. $20 dues are paid annually.
With gruppe membership you get a VKG membership dog tag keychain (exclusive “Charter Member” tag to the first 50 members), gruppe sponsor discounts, and access to exclusive VKG merchandise and gruppe newsletters.
VKG Performance Klasse Car: All German/Euro Look Air-Cooled Volkswagens (any year) that meet the minimum Performance Klasse points for each category as noted in the Car Requirements section. A $30 one-time car membership dues payment is required.
In addition to basic gruppe membership benefits, with a Performance Klasse Car membership you also get a high quality VKG window/body sticker to identify your car as a VKG car and a high quality silk-screened VKG t-shirt.
VKG Select Klasse Car: All German/Euro Look Air-Cooled Volkswagens (any year) that meet the minimum Select Klasse points for each category as noted in the Car Requirements section. A $TBD one-time car membership dues payment is required.
With a Select Klasse Car membership you also get a class specific, high quality VKG window/body sticker to identify your car as a VKG Select Klasse car and an exclusive made-to-order VKG Select Klasse work shirt or work jacket (still under development).
Car memberships are transferable in cases where the owner changes cars and their replacement car meets class specifications within 1 year. A VKG class specific replacement sticker will need to be purchased at cost. A car should not wear any VKG stickering or be shown as a VKG car until the requirements for the given class have been met.
Car Requirements
The new VKG car requirements are based on a point scoring system to determine a car’s compliance to the VKG philosophy of well balanced upgrades through the car systems. This scoring system, while it may appear like a bit of overkill, will help the gruppe ensure that all gruppe cars are built to a standard of quality to better the car’s performance and safety as well as visual appearance.
The points scoring system is based on a minimum level of upgrades on the car in each of several categories. The bigger and better the upgrade, the more points it counts for. Having to meet a minimum score in each of all the categories prevents someone from just throwing some Porsche rims on a car and some carbon fiber accents and calling it a VKG car.
There is no overall score. You must meet the minimum score in each category. As you will see, it doesn’t take much to meet the minimums in each category to have a Performance Klasse car, but even these minimums across each and all categories will greatly improve a stock VW. To have a Select Klasse car, you must meet the Select Klasse minimum in all categories.
1. Engine: Open to all air or water cooled engines. Unlimited modifications allowed to engine to improve performance.
Scoring:
Modification/Upgrade Points
Aspiration:
Ported manifolds 1
Dual carbs 2
Fully-merged header 3
Non-stock exhaust 2
Turbo 5
Non-stock fuel injection 3
Cooling:
Engine:
911 cooling system 3
DTM-style cooling system 3
German sheet metal 1
Other non-stock system 3
Oil:
External oil cooler 2
Larger oil pump 2
Dry sump 3
Deep sump 1
Full flow 1
Clutch/PP/Fly:
Upgraded clutch 1
Upgraded pressure plate 1
Lightened Flywheel 1
Displacement:
Up to 10% increase in displacement over stock 1
11%-25% increase in displacement over stock 3
Over 25% increase in displacement over stock 5
Internals:
Nickies 4
Upgraded camshaft 2
Upgraded rods 2
Dynamic Balancing (complete reciprocating mass) 2
Heads:
Ported and Polished 3
Increased Intake and Exhaust ports 3
Solid rocker shafts 1
911 adjusters 1
Ignition:
CDI 3
Rev limiter 1
Bosch 009 Distributor 1
Pointless (non-optical) Distributor 2
Optical Distributor 3
Engine Swap:
Non-TIV to TIV 5
Other (WBX, Subaru, etc) 5
Fit & Finish Variable (assigned by officers) -3 thru +3
Performance Klasse Minimum Score: 5
Select Klasse Minimum Score: 15
2. Transmission: Unlimited modifications allowed.
Scoring:
Freeway Flyer 3
901/915 trans 5
5-speed Berg 3
Other tranny 3
100mm CVs/T181 Flanges 1
Performance Klasse Minimum Score: 0
Select Klasse Minimum Score: 3
3. Brakes: Unlimited modifications allowed.
Scoring:
Non-T3 to T3 drums 1
Ghia two pot front discs 2
Other two pot front discs 3
Four pot front discs 5
Ghia two pot rear discs 2
Other two pot rear discs 3
Four pot rear discs 5
Upgraded master cylinder 2
Stainless Steel soft brake lines 1
Vented rotors 2
Cross-drilled/slotted and vented rotors 3
Stock front or rear drums -1
Performance Klasse Minimum Score: 2
Select Klasse Minimum Score: 4
4. Suspension: Car should be lowered front & rear. Unlimited modifications allowed to improve ride, handling & chassis strengthening.
Scoring:
Lowered front 2
Lowered rear 2
Upgraded front anti-roll bar 2
Rear anti-roll bar 3
Coil-overs (points per axle) 3
Performance shocks/struts/springs 1
IRS rear from swing 2
Aluminum trailing arms 3
Transmission brace (Kafer Cup style Brace) 4
Front strut brace 2
Narrowed beam 2
Narrowed arms 2
Performance Klasse Type 2 adjustment:* +3
Select Klasse Minimum Score: 10
*Due to upgrade limitations, any Type 2 bus that has met the Performance Klasse minimum can apply 3 points towards Select Klasse point requirements.
5. Wheels: 16” or larger Porsche or aftermarket wheels required with low profile performance tires. Only exceptions to this rule are 15” Porsche wheels, but the previous is strongly preferred to stay true to the look. No stock VW wheels or classic VW wheels (i.e. Empis or BRMs).
Scoring:
15” Porsche wheels 1
16” and larger wheels 3
3-piece wheels 5
High Performance tires (H or V rated) 1
Ultra High Performance tires (Y, W or Z rated) 3
Bolt pattern adapters (not spacers) Not permitted
6. Body: Body modifications should be functional & tastefully done and true to the style. Paint can be stock pallet or custom but should have a European influence.
Scoring:
Lexan windows – rear 2
Lexan windows – quarters 2
H4 or HID lighting 3
Third brake light 1
Custom paint color or scheme 4
Carbon fiber body panels or running boards 5
Non-stock mirrors 1
Single or 911 wiper conversion 2
Painted/Blacked Out trim 1
Shaved trim 2
Functional ducting 2
Weight decrease of 1%-10% 1
Weight decrease of 11%-15% 3
Weight decrease of over 15% 5
Performance Klasse Minimum Score: 1
Select Klasse Minimum Score: 5
7. Interior: Performance/Sport influenced (bolstered seats, sport wheel, upgraded shifter, etc), Race inspired (i.e., race seats, harnesses, roll cages, safety equipment & extra gauges), or stripped. No stock interiors.
Scoring:
Sport/Racing seats 3
Sport steering wheel 2
Upgraded shifter 1
No back seat 1
Roll cage 5
Harnesses 3
3-point seat belts 1
Lap belts* 1
Fire extinguisher* 1
Extra gauges 2
Porsche gauge cluster 3
Carbon Fiber components 3
Performance Klasse Minimum Score: 3
Select Klasse Minimum Score: 8
8. Theme: Overall theme of the vehicle should be consistent & carried through, from the inside out. Don't mix styles.
*MANDATORY items
Old July 5th 2004, 21:38
boygenius's Avatar
I guess wet sanding the underside of my car would get me some more "fit and finish" points.
I like the rules...
I think everything is covered.
Old July 5th 2004, 22:51
I don't know about that, Zen and I both have some back issues right now. Might not be able to get down there to see under the car.
Rules look good to me. :agree:
Old July 5th 2004, 23:12
Mikey 1972GL Mikey 1972GL is offline
The rules look good to me.
Good work. :agree:
Mike
My new user name, Mikey
for some reason, I havn't liked this name since I made it.
Sorry for any problems... Mike
Old July 6th 2004, 00:07
boygenius's Avatar
I will have to supply a mirror then so you can see the underside without having to bend down.
Old July 6th 2004, 08:41
yetibone's Avatar
yetibone yetibone is offline
I dig it!
One Q about brakes that wasn't specificly stated. Sue's Bug , and eventually mine too have Porsche single pot calipers, a-la standard 944.
Sue has 'em on the front only, with Roto-Hubs and Varga single pot calipers in the rear, and mine will have Porsche single pots on all fours.
Would they be categorized along the same lines as "other two pot disks" even though they aren't really two pistons per caliper?
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 6th 2004, 09:09
Yep. :agree:
Old July 6th 2004, 18:48
Panelfantastic's Avatar
Sounds good. :agree:
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
Old July 6th 2004, 21:58
yellow73's Avatar
yellow73 yellow73 is offline
Rules look good...I will just make it if I have H rated tires on the cookie cutters.
Old July 6th 2004, 22:22
If you come up a little short we could give you a point for your accent
Old July 6th 2004, 22:37
yellow73's Avatar
Thanks yall!!!
Old July 6th 2004, 23:17
I agree with that. :agree:
Mike
Old July 7th 2004, 01:02
Sheppsan Sheppsan is offline
Question on the wheels section. How about more classic GL rims such as ATS's on my car?
Shepp
Old July 7th 2004, 08:12
hi dale. we had talked about this offline before. we consider the ATS the one undocumented acception to the wheel rule only because of its history. so you are OK with them. the spirit of your car speaks a lot for the use of those rims too. and that is the key of what we are trying to maintain with the rules...the spirit.
Old July 7th 2004, 17:54
Zen
Understand where you are going with the rules. Think the idea is sound; they look fine to me.
Shepp
