Hmmmm. Can you post some pics. I know that the 1986 turbo had the early aluminum trailing arms with less track increase.
Well since they have the bump stop area in the arm that should make for one less challenge in installing them. :agree:
no prob, i'll have to get a camera from work so it won't be till mon or tues. basically it looks like the early alu. arm with a late turbo hub. i'll measure the caliper bolt spacing and see if there's a difference in the 2 sets of arms also
Maybe someone switched rear hubs to get more track for their car.
I got the complete rear suspension from a '86 NA and I measures the track from the spring plate and it was the later style as well as it uses the longer half shafts. I wonder if they went to the wider setup mid 86?
Thought you might like this pic.
On the right is a standard 1303 seni-trailing arm, in the centre is a steel 944 arm (which I think is identical bar the wheel hub assembly), while on the left is an ally 944 arm. I was going to use the ally job on my '03 until I saw the extra width it'll add to the rear wheels! ![]() Another point to note is that the bolt pattern for the ally arm will not fit the 1303 spring plate, where the steel will. Hope this helps.
I like the wide arms
I need the wide trailing arms for my bug. The wheels i've got are 993s the fronts are 7x16 with 55mm offset and 150mm backspacing, while the rears are 9x16 with 70mm offset with 190mm(wow!). I have 2 inch wider fenders front and rear, so i need to push the wheels out to the fender lips. Will the front hubs from'92-'95 968 add more track like the rear arms will?
