I have 993 c2 front and rear brakes and rotors.
my friend has 944 na brakes all round and boxster rims fits nicely. Go for it.
T4 2666 1303s |
I have seen an '03 with these rims fitted with 944 steel A-arms and brakes, the rear 7" ET40 stuck out from the wing buy about 4-5mm. Enough to look a bit odd.
Can I suggest polishing the rims .. .. .. seen here on my wife's lowlight Ghia Fitting them to this was a real PITA
+44 (0)7812 167547 martinandsonjaATf2sDOTcom Last edited by MdR; March 1st 2006 at 12:42. Reason: dead link - link reinstated |
I keep thinking, that would make a great German Look. Mike
My new user name, Mikey for some reason, I havn't liked this name since I made it. Sorry for any problems... Mike |
Buy it!
You gotta love a Ghia
+44 (0)7812 167547 martinandsonjaATf2sDOTcom |
Any difference in length btn stock vw trailing arms and 944na trailing arms? I'm not sure on that but I've seen my friends car, its flush with the fenders. His is stock vw trailing arms.
T4 2666 1303s |
AFAIK the steel arms are the same except for the bushings. Does your friend have 7" ET40 (boxster rears) or 6" ET50? (boxster fronts) at the back end of his bug?
6"s would fine, may well even need a spacer.
The 944 steel arms are the same as the beetle IRS, only i guess they are stronger due to internal bracing. I used them only becuase they were not rusty like my stock arms... and since there the same arms, yet stronger... why not eh?
Later! Jonathan
FULL SPEED AHEAD, HARD AND FAST! Current cars: -74 Super Beetle -86 Vanagon Syncro -64 sunroof bug -73 thing |
The only thing I can think of would be to avoid extra weight. When have you ever had an a-arm break on a road car?!?
They fit fine......... Had to use a small (1/8") spacer on front to fully seat the center cap. Still have stock fenders.
Eric Mulkey '66 Standard Walk-thru '71 Super(GermanLook in training) Las Vegas VW Club |
