Old August 10th 2004, 02:55
mikko k mikko k is offline
Nobody else have any experience with Pauter heads?
Old August 10th 2004, 03:48
I have no dealings with these heads, but I think if you post your question at this link you can get so info.
http://www.shoptalkforums.com/viewfo...63cafe514c1bbb
or here.
Good luck.
Old August 10th 2004, 08:17
Hello Mikko,
I don't have any experiences with these heads either, but I thought that the only one that does as far as I know (in my country) is Henk Hendriks (www.hotrod.nl, no info on that engine there tho). He owns one of the oldest VW aircooled shops, is very knowlegable and uses those heads in his Nitro'd tube framed dragster in a 2866 cc type 4.
My gut feeling is that they are totally unsuitable for more than 402m street driving, for the reasons you already mentioned.
As you will have guessed, Henk only drag races with that car.
Best of luck,
Walter
Old August 10th 2004, 09:45
cnavarro's Avatar
cnavarro cnavarro is offline
With engine plus heads and basically any type 1 style heads with reduced finnage, it has been our observation that a set of Nickies go a long way to reduce head temperatures, which would be a good thing to keep your seats in their place and the valvetrain together for the longest time possible. This would also provide superior sealing, which under boost, would be a difficult task unless extreme measures are otherwise taken. I've also seen Nickies go a long way to making Scat split ports reliable, so there's a lot to be said for the cooling abilities of Nickies.
For example, I'm doing a 100mm Nickies cylinder for Raby (~10mm thick sealing surface) with 3.6L 911 gas filled gaskets for optimal head sealing. Maybe this would be a good starting point to make your 300+ horsepower beast fully streetable? To keep cost down, you could always use a set of 103s, and as long as you don't pour more than 1 bar, I think it should be more than streetable (using comparables cylinder wise from Porsche).
BTW, i've been looking for someone to do side by side testing between cast iron cylinders and aluminum ones on a big turbo type 4. Drop me a line and let's see if we can work something out.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Old August 12th 2004, 18:12
Ok, thanks. I'll check these.
Charles
At this moment we are using aircooled Deutz engine cylinders bored to 4,02". Porsche fan have been used all time now and in future it will cool the cylinders, while water will cool the heads. Your Nickies are very interesting, but I cannot promise to buy those.
Testing side by side would be interesting to do. Would you send me an private message what are you thinking about and maybe your email address. I would call, but I'm so far away that when you work, I'll and otherways!
Old August 12th 2004, 18:34
cnavarro's Avatar
Will do!
Charles Navarro
LN Engineering
