Old January 4th 2005, 19:59
kdanie kdanie is offline
Many factory tachs don't work with MSD ingnitions. My VDO tach in my BMW won't work off the ignition box but works if I take the pulse off the + terminal on the coil. Try that and see if it works. MSD makes two types of signal adapters to make their tach signal work on factory tachs-they sell for about $30 or so. Call them if you want to use the adapter so you can be sure you get the model that will work with your tach.
ken
Old January 4th 2005, 20:35
Mario.D Mario.D is offline
Problems With 911 Tach and MSD
Thanks Ken,i will tray with a + in the coil.
Regards.
Mario
Old January 5th 2005, 01:59
I think the Neg. terminal is the point you want to take the pulse from. The + terminal will just put 12vdc on the sense line to the tach and could damage it.
Old January 6th 2005, 06:30
Problems with 911 Tach and MSD
Yes is a risk,i contacted MSD technical suport and them recomend use
a Tach controler PN8910 to control the -pulse to the tach.
Thanks.
