Old January 31st 2005, 23:46
Scotts73SB's Avatar
too much oil pressure
Hey guys -
Im having a problem with the new engine im building.. seems on start up the oil pressure is at 80psi and climbs with each rev.. dont worry i shut it down and pulled the motor all apart already. Im thinking its stuck oil pressure relief valves. Anyone else have any suggestions?
its an 1835 dual webber engle 110 cam
hi volume oil pump was using 20/50 oil. Remote 76 pass cooler.
All clearances are right on. Seems the oil pressure has no where to go so it just builds.
Pressure at idle is 75 and can get it to 250 when it revs. I know this isnt right..but im hoping someone might have some insight why it does this. Ive narrowed it down to the pressure relief valves being stuck in the bores i think.
Any help? Thanks!
- Scott
Old February 1st 2005, 00:09
The valve must be stuck. My engine has some high pressure at start-up. I blew 2 Volvo oil coolers when I fired it up, but it is normal when the 20w50 warms up. I went to a full synthetic 20w50 after break-in and it flows much better at start-up.
Old February 1st 2005, 02:03
Scotts73SB's Avatar
Thanks... just needed some reassurance. Im gonna get the case cleaned again and oil galleys cleaned and blown out again just to be sure and make sure the pressure relief valve pistons move up and down with out the spring first.
Im sure i couldda blown the oil filter if i reved it past 3 grand.. that wouldda been a mess.
Old February 1st 2005, 05:28
I blown a couple filters(seals). I went to a K&N oil filter and haven't blow one since(550psi rated).
