Old March 30th 2005, 10:00
CLKWRK's Avatar
CLKWRK CLKWRK is offline
Heya Pete,
I figure if your dry sump is doing its job, the sump should be close to empty most of the time, thus giving you a lower reading than you actually should be getting.
I take mine at the pulley side releif valve, that way it gets a constant flow of oil and i know the oil temp as it enters the case before its used by the engine.
bry
GL ghia restoration:
