No Oil Pressor...
Hey ..
Iv just had my motor running long enuff to check the guages.. Fuel Press is holding at: 4.6lbs Oil: -N/A- My Guage has power & the sender wire is hooked up.. Maybe bad new sencer? Things Im Checking on.. Pull Valve Cover To see if it has oil.. Recheck sender & wires.. What all can you think of.. the motor ran fin before the overhall. I changed the valve covers,header/exhaust,Carbs,fan,alt,tins,wiring ign system,fuel system,pully system >>1st Time Running Video<< Thanks N Advance Peace Troy
SOLD!! 65 Bug 1835cc,Duel Dell 34's,BMD Serp Belt, A1 Perf. Sidewinder,CompeUfire Pointless Ign 95A Alt,CSP Valve Covers,Randar Diego 16's Soon [URL=http://www.cardomain.com/id/troy_audio] |
for your oil pressure gauge, are you useing a special sender or the stock sender? The stock sender isn't made for a gauge, only to make a light in the dash go out when there is pressure, Just to be courius, is the engine/transmission grounded to the frame?
I checked the covers..
they had oil in'em i found a small leak by the oil fill/breather Bottom edge leaks(Drip drip drip) 6" marking over night I will check into my wiring & sender when I get back toit Peace VDubz 4 Life c(<>_<>)0 |,,|_
I just looked i dont see a ground strap on the block.. but Maybe on the tranz.. Need to jack it up..
if you're using solid mounts or you didn't take the tranny out, it should be there.
if your running a full flow setup try taking the line off the pump cover, pour some oil down it, then try starting it. mine doesn't like to prime after a build and that always works for me. btw- leave the line hooked to the pump cover itself, unhook it from the other end
Im not full flow yet..
But i will keep that inmind for after I do.. Iv been looking for leaks & found a few.. Dip-Stick,Alt Stand,Filler/breather on the mounting spot.. I think (As stated)My Oil Press maybe for a Light only.. But its running ok for now.. lil timming & carb tuning then i should be ok.. Peace Troy
