Old May 19th 2005, 21:32
LLVWGL LLVWGL is offline
well, I cant really because I have an early 1303 with 1302 front end.
Old May 19th 2005, 23:17
oicdn's Avatar
oicdn oicdn is offline
Question is, is if you can use NA hubs for Turbo brakes.....
I would assume you could use the drum ones as the Vdub customs' kit for supers used stock spindles and supers have drums up front.....my guess.....
Old May 20th 2005, 02:24
Superman
No, the hubs/discs have a different offset where they mount together.
Old May 20th 2005, 03:10
I'll probabaly have the hubs machined, since it would save me from having to buy new struts/springs/sway bars and all of that other junk i have under there.
Superman
You need to put the 1303 suspension in your car and then the 944 brakes. I had to do that to mine.
