Old November 24th 2002, 13:19
2056 t4 motor
2056 Massive Type 4 engine
All parts by Aircooled Technology
914 engine case
Standard remanufactured 2.0 liter crankshaft, machined less than .010 on main and connecting rod journals.
Standard 2.0 liter, balanced, and matched rods, re-bushed and completely rebuilt and checked for straightness.
Web cam made to Jakes specifications.
Web Cam, Solid lifters and Cam Gear
Keith Black pistons. All rings are hand gapped, pistons balanced.
Cylinder heads
1.7 914 Heads, opened for 2.0 cylinders, 42x36mm valves, single heavy duty springs. All work done by Head flow masters. CC’d to 57 cc’s.
Solid hydraulic type 4 rocker spacers
Genuine 911 Adjusting screws
Chromoly steel pushrods
New push rod tubes
Modified type 1 oil pump with 30mm Gears
Berg full flow oil pump cover
Stainless braided oil lines with aluminum AN fittings
Cleaned and pressure tested oil cooler
Weber 40 IDF dual carbs
Aircooled Technology estimates 125 hp
For bug conversion, includes:
DTM cooling shroud
BAS Sport racing steel header, 39mm ID tubing.
BAS Stainless Silencer system, twin muffler
Great deal at $4750!!!
Located in NC, can be shipped
Please contact with any questions. If I can’t answer the question, Jake Raby can.
Please contact John:
jhelgesen@aol.com or jhelgesen@rennlist.com
63 356b time capsule
948 project
