Old February 19th 2005, 03:35
BOBTAIL BOBTAIL is offline
http://www.experiencelemans.com/inde...tml&lang=en-us
I saw this and thought of you
Old February 19th 2005, 14:30
Cool, thanks!
Never knew a 4 valve aircooled head with aircooled cylinders was made
Regards,
Walter
Old February 19th 2005, 14:44
Wesayso's Avatar
Wesayso Wesayso is offline
Walter, you might want to take another look. It looks like watercooled heads with aircooled cylinders... or was that what you were trying to type :agree:
I've seen the later total watercooled 4 valve heads with cylinders in one..
cool stuff!
Old February 19th 2005, 15:05
Yep, now I see it! your right
Old February 27th 2005, 17:26
Wesayso's Avatar
Hi all,
Just wanted to anounce a small update on the Apfelbeck project with some new 3D Graphics...
www.Apfelbeck.nl
Old May 1st 2005, 15:49
Wesayso's Avatar
Another update on the Apfelbeck Project...
Some of you might have seen the first pictures of our new Cylinders on Jake's forum at the STF, but some better Pictures are available now on www.Apfelbeck.nl
As well as a new look on the Home page
Enjoy!
The Apfelbeck Team
Old May 3rd 2005, 10:09
wow. very cool stuff. great progress. looking forward to more info as it becomes available. these are the type of innovations that will keep this hobby alive.
if i can include any pics in the GermanLook.com gallery, let me know which.
Old May 4th 2005, 09:02
Bad bug's Avatar
Bad bug Bad bug is offline
New heads
Hi Guy's
I thought these heads would bolt directly onto a type 4 engine. Will it be this way or will we have to purchase pistons,sleeves and heads as a set.
Old May 4th 2005, 10:47
No, the development of the cylinders is totally separated from the heads.
Its was also (amongst other reasons) an opportunity to see how our selected aluminium casting company would produce something with as close a finnage as possible since there are limitations with sand casting.
We (and the casting company) had our worries with the cylinder mold, but the very first result is already better than I (and we) expected and that is also very good news for when the final mold for the Apfelbeck head is finished and is the reason we were very exited about the cylinder result
Best regards,
Walter
Old May 10th 2005, 12:43
cnavarro's Avatar
cnavarro cnavarro is offline
Great idea to do a 98mm cylinder, similar to those done back in the day by ottinger (sp?), but to encapsulate the head studs to provide additional rigidity, especially if you get the desire to put a turbo on there. The only thing I will be curious to see is how well they cool, since we actually de-encapsulated the head studs on all our 930 cylinders to provide better and more even cooling. It was only with the 993 (3.6,3.8) that they absolutely have to be encapsulated, as there just isn't enough meat to seal them off otherwise. Are you going to go one step futher and flame ring the cylinders and heads, to ensure proper sealing. One could easily use some from 3.4 cylinders and adapt them to work. They would be overkill with the registers you've used :-)
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Old May 11th 2005, 05:22
Charles Navarro
LN Engineering
Hi Charles,
What do you mean by a 'flame ring'?
If you refer to the late 964 and 993 cylinder-head seal that is embedded into the top of the cylinder wall, then the answer is yes, but not the same ring/material will be used .
Also the cylinders may probably not be Nikasil coated, but with a substance of even less friction, at least as hard as nikasil and lower cost (for our 4 seperate cylinders at least). Its a bit experimental, so I/we can't say/know much more about it yet, but we love this kind of thing and it will be fun to see if it works.
Regards,
Walter
Old June 10th 2005, 11:21
Wesayso's Avatar
A week ago we gave a presentation of our Apfelbeck Project at an Autodesk Inventor User Group meeting. For this event we played with the new Inventor Studio to create a new movie. Needles to say that movie can be found on our site www.apfelbeck.nl
A small preview:
Old June 10th 2005, 12:00
cnavarro's Avatar
If you have them cast, why not use alusil and then have the pistons cast-iron plated? As far as flame ringing, there are a multitude of aftermarket designs where the cylinder and head have a ring groove machined into both and the ring actual interfaces with both surfaces. Some are an actual groove whereas other are a ledge (which leaves the top surface thicker at the failure point).
Old June 10th 2005, 13:43
libila libila is offline
I've been reading all about this project and I'm happy to see the consistent updates and discussions. Great work so far! I can't wait to see phase five.
I hope to see a write-up of each individual test car when the time comes, especially the 4wd autocross bug.
Old June 12th 2005, 11:36
oicdn's Avatar
oicdn oicdn is offline
Thank god I'm doing my motor last, looks promising and gives me time to save.
Hmm...a Turbo version, lets see how crammed you can get the engine bay Would also be sick as hell....
