I used the same axles for early aluminum arms too :agree:
I got a 914/901 box with stock 914 output flanges with threaded dowel holes. My inner joints are stock Type I, and outer joints are stock 944S.
Yetibone you stated you used the same drive shafts for your conversion. I take you mean't you used the 924 drive shafts with the 901 box. Did I read this correct?
So you are saying the 924 drive shaft with the relavant CVJ will do the conversion over to the 944 Ali A arms. Can you please clarify this matter for me. Cheers VEEMAN |
I didn't elaborate much, did I? My axles are from an '87 944S. They are almost 21.5" long, and have 33 splines on each end. Type I CV's will slide right on. Any 944S had aluminum arms, and thus the longer axles. I don't think any 924 axles will work for this conversion, unless a 924S came with aluminum arms, which I genuinely don't know if they did. One point that boygenius told me about is that axles from 924, and 944 Turbos may not work because although they are the right length, they are splined differently (28 splines, I think). Veeman, be lookin' for an '87 and later 944S, or 944S2, with a manual transmission for your axles.
Yetibone '71 1302S 1.8 '73 1303S 2.3 '83 928S 4.7 Last edited by yetibone; July 4th 2005 at 18:39. |
The manual vanagons also use 21.5" axles. They will take T1 or T4/944 joints.
Lanner |
Yetibone, thanks for the info. I now can see that there is an 5" difference between the 944 compared with the 924. That's going to leave me short by 5" if I use 924 driveshafts.
Flat,thanks for your comments too. By the way what is an equivalent model to the Vanagon here in the UK? So fitting the 944 A arms to the 1303 is there any problems with bolts on the 944 spring plates catching the suspension top mounting bracket that starts behind the torsion cover? Have you guys had any mods that you have done to fit or is it just a straight bolt on conversion. Any advice will be appreciated. Cheers VEEMAN |
