Old October 16th 2005, 00:14
GRMNLK's Avatar
GRMNLK GRMNLK is offline
Swing Axle, TIV, 40 series tires???
So I did some searching and found alot on 901 boxes and other porsche stuff (interesting reading) here on GL. But I have a couple unanswered questions.
I'll be rebuilding my '63 S/A trans. and will be hooking up a 2.4 TIV to it, and I'm running 205/40/17's. My gear ratio is really bad in the city, I'm usually cruising in 3rd gear at 35-40 mph, and horrible on the freeway....4th gear at 3,600 rpm is about 65 mph.
So I think 1st and 2nd are fine but want to widen 3rd and 4th so I can cruise around 75 mph at 3,500-3,800 rpm.
I'm curious as to what gearing you guys are running for freeway speeds with 40 series tires and big motors? Thanx
Well after some more searching it dawned on me to check Jake's site. I found out some useful information, I'd like to get the stage "C" kit but not for 1,599.
I need a hopped up stage "B" kit, but not quite a stage "C"
http://www.aircooledtechnology.com/Home_Page.htm
Twisted '58
Twisted '58
Twisted '58
Old October 25th 2005, 09:13
Bad bug's Avatar
Bad bug Bad bug is offline
I am thinking of doing a motor similar to yours 2.4l in the futur. One think only if you could get a irs chasis it would make you car a true germanlook plus it's better for handling. On a matter of gear boxes if you can get a 3.88 ring and pinion box you will be flying.
Old October 30th 2005, 17:24
Bruce2 Bruce2 is offline
At a very minimum you need to get a 67 or later swing axle trans from any car that came with a 1500cc or 1600cc engine from the factory.
The later SSC trans with an AT code will get you a 3.88 R&P. You can take that and use it with an earlier Beetle .88, or a Bus .82 to get taller gearing.
Old October 30th 2005, 18:02
Bad bug's Avatar
Bruce which of the bus gearbox had the .82 fourth gear. I am about to build a new gearbox with a brasilia bus case.
Old November 1st 2005, 02:53
I don't know what year Bus trans has the .82 fourth. There does exist .88, and .85 Bus 4th gears as well.
To use a Bus gear in a Bug trans, the doner trans must be from before 1976. A 1976 and later 091 Bus gear will not work in a Bug trans.
Do you have a pic of the Brasilia Bus case?
