3 - Dellorto 45 carbs
1st one is like new, everything is smooth as butter (45D) 2nd on has a tight throttle shaft, not smooth(45S) 3rd has a very tight throttle shaft and the throttle blades are removed (45D) Lots of extra jets, emulsion tubes, main jet holders etc. Some extra 28 vents, a couple 35 vents and one 42 vent (I don't think this one if Dellorto, possible IDA). Has T1 manifolds, air cleaner brackets, etc. No linkage. ![]() ![]() ![]() $C580/all |
T4 1.8 Rods/Crank $C120,T1 Stock 69 Crank $C100 (stock, never cut)
![]() T4 2L Rod/Cranks $C180
Loaf,
Yeah, it's from an early 911. Email me lanner@vdubcustoms.com with your address so I can generate a shipping quote. Easy, Lanner |
what condition is the TIV 2L crank and rods? Are all the surfaces smooth still? And is it all stock? Thanks JR
The 2L crank and rods are in really nice condition. I was going to build a motor with them, and I only intended to micro-polish the journals.
More stuff:
New aluminum oil cooler (really light). Used SPAL fan (the fan has been dropped and suffered accordingly by breaking one of the 4 mounting tabs).The fan is still definately usable. $C145/set 210MM bus flywheel. Ideal for the T4 motor to T1 tranny engine swap. Needs some machining to fit the pilot bearing. $C65 Early 944 (84ish) spindles with backing plates (for 1303-944 conversion). $C70/pr |
that 914 gauge pod has tach & fuel gauges?
