Old November 16th 2005, 05:23
Originally Posted by ricola
What happened with subaru idea?
Rich
My guess is that he got infected by some sort of Scandinavian virus
BTW, what is PWR ?
Old November 16th 2005, 06:19
Racelook's Avatar
Racelook Racelook is offline
Walter,
PWR is an company that makes thinks for o.a. racing cars.
http://www.pwr-performance.com
They have verry nice Intercoolers (air-air and air-water)(also the one that Ian Swinkels had used)
Wiebrand
B-Extreme B-Tuning.....
Old November 16th 2005, 10:47
The turbo system for my T4 was about 90% complete when I started researching the WRX conversion.
I had a motor lined up and then I got some bad #'s from the owner who had really abused the motor.
I got a quote from Kennedy Eng for a kit with clutch/PP that would handle 300 hp and I thought it was outrageously priced.
About that time, some crazy Scandinavian proved with hard #'s that you can get 234 HP and 258 ft-lbs from a stock 2.0 Bus engine with some headwork and a TD04HL-16T
Well, add these up and you can see why I'm going to finish this T4 turbo
I just ordered my IC today. Looks like I may need a second seperate water circuit for the turbo .... wonder if a 12v waterpump for water cooling home computers has enough flow capacity.
Old November 16th 2005, 12:12
samcat's Avatar
samcat samcat is offline
Is not the flow thats the issue, its the temperature range of the liquid, most PC watercooling pumps WONT like the sort of temperatures it would see in this circuit.
Eheim 1250/1260 would be the most likely, but they are mains powered and have a lot of plastic...
Sam C
Old November 17th 2005, 13:14
scoobytuner scoobytuner is offline
dude, you dont have to run the water lines to that turbo at all. i reccommend not even hooking them up. the turbo does not need to be plumbed with water, just oil. Infact, I had a stock turbo on my built car for a while, and i ran it with no water going through it. the one thing you just have to make sure of is that you dont run it too hard, then shut it off right away, the oil would be too hot, and would cause problems.
but seriously dont even run water through it at all.
Old November 17th 2005, 14:09
Yeah, they just spend a bunch of energy to engineer a turbo water cooling system for no reason !
Old November 18th 2005, 00:13
no, they do it so you dont have to idle your car for a minute before shutting it off.
believe me. ive done it and so have many others. with not one ill effect.
Old November 18th 2005, 03:16
verno-dub verno-dub is offline
Quoted for truth. Adding the water lines to the turbo will add complexity to your install that you really dont need. But I would add a turbo timer to prevent coking the oil in the center turbo bearing section. I would also reccomend running a 5w/50w or 15w/50w synthetic, your turbo will thank you. I run it in my STi powered GC8 and I have heard no complaints.
