Old November 20th 2005, 18:17
Originally Posted by beetle1303
I suppose that you wouldn't mind the work involved. As i said before "boxing" the rads inlet can improve air flow under the curvy beetle's front end. I believe that you could even benefit from using it. Actually have you seen a kamei spoiler with the oil cooler opening?
Chris
I'm doing the "boxing" think to the max. I'm going to have a lip (flat plane) that is below and in front of the nose. As air is forced down under the nose, it will hit the lip, which will then duct it into the radiator. I had this radiator custom made with a lip on the front and back of it to attach the ducts to. I hope it works!
