Old December 13th 2005, 05:00
Bruce2 Bruce2 is offline
Originally Posted by lazylongboarder
Ok, you want a straight answer, chew on this. Drag boxes for 500 bones handle 150 lb/ft of torque tops. The 901 will handle 250 lb/fts reliably. A 915 will handle 350 lb/ft of torque tops. A 5 speed G50 from a 964 will handle 600 lb/ft of torque. A 6 speed G50 will handle 800 lb/ft
Where did you get those stupid numbers? Cite the scientific testing that was done to determine those cutoffs. They look like SWAGs to me.
I can build a Type 1 gearbox that will easily take 200ftlbs for less than $500.
Whether a trans can withstand a certain peak torque has very little to do with the design, and much more to do with the idiot behind the wheel.
Old December 14th 2005, 11:07
lazylongboarder's Avatar
lazylongboarder lazylongboarder is offline
Originally Posted by bean_8044
Any thoughts on a Boxster trans? theres some cheap-ish ones on eBay
Well since it's a mid engine design, you'd have to flip the rp or flip the tranny upside down, so mounts would be an issue for those of you looking for a bolt on install . The 3.2 in there puts out 270 hp and i've seen aftermarket turbo kits putting out well over 400 hp in a 3200 lb car...so in short, yes the boxter tranny would work, the S models have a 6 speed but you have to worry about custom axles and so on...
The reason why i'm doing an entire 993 rear end is cause i'm using it the way porsche designed it. I got some suggestions of possibly narrowing the whole suspension setup, but even if you're really really good, you'll screw up the geometry and it won't work like it's suposed to. I can use stock axles, stock hubs, stock sway bars, stock 6 speed g50, and bilsteins PSS9 setup, all without killing the geometry...
Russell
1974 type 1
Turbo 6 piston brakes at all corners
Project is taking all my money and it's all Germanlook.com's fault!
98' Audi A4
93' T-Bird (oh yeah!)
90' 911 C2
74' beetle
