#16
www.remmele-motorsport.com
sells both fiberglass and carbon fiber doors... (see the "plastics" section)
there's got to be more to life than being really really really ridiculously g00d l00king... |
#17
thanks quick
YEAH ITS GOT A HEMI |
#18
Have you ever worked with fiberglass? If not you would first need to learn about all the chemicals and different fabrics and their weights. You would then need 2 perfect doors (each side). Make a mold of each door. If you wanted the top of the door to have a rounded edge on it, make that more work. Then if you wanted to have a working window you would have to glass in the metal mounts for the regulator to bolt up to, glass in metal nuts for the weather strip, glass in the metal nuts for the door handles and latchs to bolt up to, and glass in the inside part of the door. It would be a lot of work and it would not protect you from any side inpact at all. If you have a cage then ignore the last part. It would be really expensive unless you know somebody that works in a shop and could get you a discount. Glassing is fun but making big stuff is time consuming and expensive. Most stuff you can find already made elsewhere. Mike |
#19
thanks and yes i built an airplane in my grage called a long-ez it was designed by burt rutan it was my dads build but he is algeric to fiberglass so i took over at the age of 14 we call her lumpy
#20
bow - No, is the answer.
![]() With that said..., for grins and giggles this is about as light within reason you can make a hypothetical flying beer can, using something that resembles a VW beetle door slammer. This won't be NHRA legal, just a Saturday night special. 128 lb. - motor no cooling, no generator, no external oil filter, stinger exhaust, non counter weighted crank, and a 12 lb. FW. 3 lb. - 14v Drill motor battery (2volts extra won't hurt). 165 lb. - swing trans, wide5 drum brakes w/drill holes to lighten and rear brakes only. 26 lb. - both back wheels, M&H slicks - 6" wide Michelle rims. 17 lb. - both front wheels, shaved 125's - aluminum wheels, spindle mount. 200 lb. - tube frame car, alum. front end, 1 seat and belts and 1 gal. fuel tank. 300 lb. - body w/aluminum beer can thin floors, gutted interior, tubs-n-rear section, glass tilt front end, lexan windows. 120 lb - driver..., ![]() 7 lb. - 1 gal. fuel NO - pressure gages, tach, starter, rear horns to set transmission in (hang it from da'cage), and no torsion housing (look at a FV1200 vw track car). Yes, this will take some planning, but if you want something close to that 800+/- number bad enough, this is how it's done. 966 lbs. are the numbers here, my alcoholic rail was 1040 wet (driver and fuel), that was about 1982-84yr. |
#21
well that is pretty much wat i have rigt now minus the 1 gal fuel tank i run a half gallon i made
#22
^ i wish. i have been expirementing with some stuff ,but i have just been enjoying my fat slow bug right now i love it
#24
hey I have email remmele and I was looking at the cup fenders he said that he would send them to canada but it was 220$ shiped on a boat plus the cost of parts but I think it's well worth it they got some sweet parts, or you could take a trip there and bring them back with ya
Thread Tools | |
Display Modes | |
