Old May 12th 2006, 10:24
petevw's Avatar
petevw petevw is offline
Unhappy Distributor Drive removal tool?
I can't get the distributor drive out of the case. Engine is in longblock form. I used a magnet to pull it up while rotating the crank slowly. It keeps getting to a certain point then binding on the crank gear.
What else can i do?
Does anyone have a tool for this (in the GTA)? Can i borrow it?
'72 super
'65 bus
'52 split
Old May 12th 2006, 11:51
CLKWRK's Avatar
CLKWRK CLKWRK is offline
If the engine is out you can flip it upsidedown.
Bry
GL ghia restoration:
Old May 12th 2006, 20:46
petevw's Avatar
True but that will be a mess. Whatever oil is left in the motor will be everywhere!.
BTW, I got my autocraft pickup and it DID come with the fitting.
'72 super
'65 bus
'52 split
Old May 13th 2006, 16:15
JIMP JIMP is offline
Hello
just take a look underneath the drive for a washer or washers, not a very good idea to leave them inside the engine!!
JIMP
Old May 14th 2006, 22:15
flat flat is offline
Pete,
I got one...give me a call...
www.vdubengineering.com
Old May 15th 2006, 01:49
Silly question. Do you have the fuel pump removed?
Old May 15th 2006, 05:29
petevw's Avatar
Thanks Lanner, I'll call you.
The fuel pump in removed. I can see a coulpe washers underneath the drive. I should be able to contain them.
'72 super
'65 bus
'52 split
Old May 21st 2006, 11:35
kai4130 kai4130 is offline
I use a pencil, just ram her in where the little spring should be after you have removed it (she should be nice and tight), and in the famous words from John Haynes simply remove.
