Old May 21st 2006, 13:19
02cab 02cab is offline
porsche fan opinion?
to cut a long story short i have a porsche fan and one of the blades is chipped at the top,its lost about 10mm of 1 of the corners and would need welded and smoothed off to make good again,would i then need to get the fan balanced or would it be ok?
thanks
Old May 21st 2006, 14:01
volksdragon's Avatar
i would get it balanced
Old May 21st 2006, 14:55
Welding it would be tricky, as its made of a magnesium/alu alloy...
Functionwise, its still ok tho
Old May 21st 2006, 18:55
i thought it was just aluminium,maybe not as easy to weld then,looks ok from the front so maybe just sand blast it and powder coat it would be ok,is the housing aluminium or does that have mag in it 2?
Old May 21st 2006, 19:51
Only the fans from the old 2,0 ltr 6-cyl 911's were fully aluminium...
If you have a magn fan, then the housing is magn. also.
Old May 21st 2006, 19:57
Bad bug's Avatar
Bad bug Bad bug is offline
Wally what ever happened to your white super and the 2.4ltr motor. I have a 911 11 blade fan with some damage also, was thinking of replacing the fan. Wally are the guy's near finishing the 3 valve heads as yet.
Old May 21st 2006, 20:12
1) It will become a 2,7 ltr in time
2) Nope.
