I'm sure having the horns tied to the engine will help. Yeah, if compared to stock it takes about the same amount of time. Then I'm sure it's good to go.
Good work. Are you going to modify those headers for more ground clearance? Im going to stick with the stock ones until Im looking for that last bit of HP. Steve
I have these seats in my bug. Similar to yours, but narrower..
![]() http://www.cobraseats.com/offroad/aqua.php
fastbug.net | FastTrack Dub Club "Straights are the boring bits that link corners together" |
Steve,
I don't want to modify the header before the collector if I can help it. With the tranny and engine raised I don't think I'll have to but I have to drop the car off the jack stands to see how it sits. Maybe something to do before the weekend. I didn't want the stock header because it's really restrictive and I'm converting from a twin turbo to a single turbo setup.Chris, Those seats are almost exactly the same size as my new seats. the Corbeau fx1 didn't fit so I swapped them for fx1 pro seats which are very close to the dimentions on your seat. Have you had much track time with your seats? How do they feel in day to day use? |
If you can use the headers you have, it will get rid of the WRX rumble for sure, everything looks different when the car is jacked up. One of the quickest WRX tuners down here only uses the stock single turbo header after he does a port job on them. I temporarily put some Recaros in my daily driver when I went up the coast to VW show a few weeks ago, its amazing how much better a car is to drive when your not slipping around on the seats. Steve
Chris,
Its good to hear the seats aren't too rough for the street. I want to drive the bug to work a few times to hit a dyno on my lunches. I'd also like to make a couple longer drives to hit a few bug shows here in Cali With your seats did you get the lumbar pillow or did you go without it?Steve, I really hope this header gets rid of the subaru "blat blat blat blat" exhaust note, I really don't like it. I have heard a couple of EJ25s with 4-1 exhausts and they have that big vw flat 4 sound to them. I know what you mean about the stock seats, I raced for a couple seasons of hillclimb and autox on stock seats. I usually took a passenger if I could to help keep me in place
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
