Ok found some uerethane that should work just need to cut it to size. I may mount it to a metal cup win a three coil spring attached to it to give it some springy resistance. [//[( kinda like that. I will have a better drawing up later when I am not at work. LOL
Pirate VW Services is looking for weber IDF and IDA carbs "to far gone to repair". We are also looking for 74 Super Beetle and later controll arms that are to badley bent to use or repair. PM for details. Sevice with a yarrhhhh! |
yea, urethane is mostly not very compressable.... the spring idea seems like it could work as long as there isnt a chance of the cup and urethane pivoting inside there and ending up sideways..........
How springy and squishy were the foam stops?
they were like....maybe as springy as the bottom of an air sole running shoe...... (best thing i can think of off hand to compare)
i would imagine a urethane type rubber would work though. |
Right. Adding a spring is going to make the stops to wide. Just going to have to be a chunk of uerthane.
