Old December 15th 2006, 00:27
martilo's Avatar
martilo martilo is offline
Howto: Removable apron (including adjustment access for carbs)
See the plate horizontally mounted inside the engine bay on the next pic:
11- We’re almost done, seal the plate with the seam and joint sealer and bolt in place. I use the sealer also along the cut. That’s it, final result bellow: (note its only mocked up on the pics and not finally tightened and/or adjusted, thus the cut look wider than final)
