Yeti,
Now it is clearer than mud to me i get what you are saying. Steve C, thanks for your aditions too. When I searched this site for home made braces, yours came up!Anyway, I just want to confirm some of my dimensions of you guys dont mind... between the two close studs, I measured 64mm and between both of the two studs close to each other, towards the further-est stud, I measured 125mm. Would you concur?? I am considering the triangle part, but dont want to loose the spare wheel space, as the trunk will still have to serve it's purpose.... where else do you guys think I can attach it to the chassis? Thanks!
Zeroaxe |
Once those pieces are cut out, bolt them into place on the strut towers of the body with the strut crowns in their place below. Tack-weld your clevis ends into place on those new pieces, and measure how long of a bar you'll need between the strut towers. Your body dimensions may vary slightly from mine, so it's best to measure what you'll need, minus about 70mm total for the clevis' at the ends of the bar.. Quote:
It'll still fit into the boot with the decklid closed, it just won't sit flat into the recess anymore.
Yetibone '71 1302S 1.8 '73 1303S 2.3 '83 928S 4.7 Last edited by yetibone; February 4th 2007 at 11:28. |
Yeti,
Thanks for the break down. Good news, found some old struts not mounted in the piles and piles of spares I have here!!:agree: Now I just need to unbolt some things, hopefully tomorrow night. The new studs, do they have to be high tensile steel? I would think so. Now, where in the name of ***** can I find a site online in France that sells nuts and bolts? (off to fleabay.fr to search)
Zeroaxe |
