Old February 8th 2007, 13:32
First update:
Order this
http://cgi.ebay.co.uk/VW-Beetle-body...QQcmdZViewItem
should be here next week
Since the cover has the wheel openings closed i can shape the fenders to the original. Along I will try and make a floorpan and the trans, engine, axles and wheels to fit under as in a real beetle.
I will post pics to follow.
For my body kit version i will use either thin pvc sheets so i can shape them, and epoxy to mount them and filler paste to perfect the final model
Im thinking of doing half stock and half modified, and seperate them with a pvc wall running across the centreline of the car.
also i will try to make the roof spoiler (lip) that goes above the rear window
Chris
Aircooled 4ever
1973 1303 going towards GL
Old February 8th 2007, 17:40
Chris
I am very interested how much lift a beetle creates at high speed (say above 100 mph ++) and how much the roof (lip) spoiler can do to prevent that.
Couldn't you just drive-in a complete 1303 in there? That would be só cool!
Thanks,
Walter
Old February 9th 2007, 14:40
judgie's Avatar
judgie judgie is offline
dont know what i can do to help, but anything i can do just ask.
can tell you that the front splitter had more effect on the handerling than the rear wing but the rear wing improves the high speed stabilaty.
cheers rob
Old February 9th 2007, 15:45
bigguy bigguy is offline
from what i have always been told is the lift on a beetle is directly related to air trapped in the fender areas. if you have releif holes or louvers in the back of the fenders it helps in stability of the car at higher speeds. seems logical since it is more directly the shape of a wing. but i may be wrong. just figured i would add what i have heard.
Old February 9th 2007, 16:35
I think that is a very good point !
Now if he could just prove that as well in the windtunnel
Old February 10th 2007, 03:31
Thanx for the replys guys!!!
bigguy, Ive already considered the relief vents on the wings, i just need to prove the best position and the see the results. The problem is that while the best place for the slots/holes for fender relief might cause too much turbulance on the side of the car. This is for stock shaped fenders... In my high speed version body kit the fenders look more like a 935 k3 porsche
Why not fit a 1303?? i wished the tunnel was that big. A motorbike fits though with rider, so i thought that I could use the right side of a real beetle since length and height are not a problem as is width.
If this works, Judgie, here is where u can help a lot with your skills. maybe fab and try different spoilers... and here is where we could try NACA duct (or any duct) positioning with a different piece of equipment we have that measures relative pressures on surfaces ( the lab i did was based on a NACA aerofoil and we measured 14 positions around it at 5 different angles of attack)
Wally, 100 mph is 160 km/h which is 44.44 m/s. I will start at about 80 km/h (around 22.22 m/s) and check the model's rigidity, and if it all is well, will crank the thing up to 70 m/s (almost 252 km/h - 157.5 mph). I am really interested in high max speed aerodynamics, cos i want to prove that with the correct modifications to the fenders, bonnet and decklid, this kind of speeds is achievable (while NOT altering the centreline profile of the roof and the shape of the roof )
Cheers,
Chris
Aircooled 4ever
Old February 10th 2007, 05:35
I am really interested in high max speed aerodynamics, cos i want to prove that with the correct modifications to the fenders, bonnet and decklid, this kind of speeds are achievable (while NOT altering the centreline profile of the roof and the shape of the roof )
Cheers,
Chris
Chris,
I'd say: Go for it! This sort of thing is really interesting and worthwhile (as in saving lives for us dumb *ss*s that actually try to drive too fast with a 'naked' bug )!
