I am attempting to fit a 9" 993 Cup III with 55et wheel under stock rear guards. I have a 26mm spacer and have had to cut the bump stop. the tyre currently on the rim is 255 which is too wide and sits out about 10mm, it should fit with a 235 tyre. I'll post a pic when the I have the 235 tyre fitted.
Dang Dirk! That car is super hot! Love the exhaust!
Would you mind sharing how the exhaust was made? Thanks,
i will post an few pictures this week
Fitted up the 9" 55 et Cup 3 with a 26mm spacer on the rear with stock 1303 guard, tyre fits under nicely. I did have to pull it a touch so it clears on heavy cornering on bumpy roads. There is also minimum clearance at the spring plate and the bump stop has been cut back about 12mm. I dont think you would get a wider rim under a standard guard without substainsal modification.
Cheers Paul |
