Old May 7th 2007, 01:41
chipmcluk chipmcluk is offline
Narrowed rear...IRS
The wheel/tire combo i'm trying to stuff in my 74 isn't quite working out. I wanna use stock fenders and have rear wheels tuck up/in the fenders slightly. Thought i had read some where about modifying the trailing arms and using two left automatic type 3 axles. Anyone have any more info about this, details?
Old May 7th 2007, 14:58
Shadowbug's Avatar
narrowing the trailing arms can work well with some combinations, but in my case the limiting factor was the spring plates, make sure thats not the case with your'se, or you could be delving into a whole lot of work for no gain.
a few pics of my project
Old May 7th 2007, 16:35
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Big question I've got is how will that affect handling of the vehicle?
Old May 8th 2007, 06:46
I have also seen the hub assembly narrowed, it involved cutting a square hole through the aluminium caliper carrier and bolting on a new steel plate with holes in to bolt on over the bearing, I think you can save about 18mm per side without having the hassle of modifying axles. There are some pics on VZi somewhere of it done on a very nice black cabrio with fuchs.
Rich
Old May 9th 2007, 00:26
Where can i find those pics? The rear rear on mine is still drum braked....no caliper carrier.
Old May 9th 2007, 07:48
Ah, sorry, for some reason I was thinking you had 944 rear brakes, the mod I describe brings 944 width back close to stock.
Rich
