Old June 19th 2007, 07:20
hak134 hak134 is offline
Test Fitting Porsche Twists
Hey folks.
Just got my Porshe Twists. I'm simply trying to get an idea of the spacer width for my rears...
In test-fitting the 5-by rim on my current 4-by drum while I send out for my discs to be redrilled, won't 2 of the 5 holes match up with 2 of the 4 on the drum for a tempo?
Hazen
Old June 19th 2007, 11:50
vujade's Avatar
vujade vujade is offline
only 1 hole will line up. You can bolt it up really tight and will be able
to set the car on the ground. I have done it before...
WinterJam 2010
Old June 19th 2007, 12:59
oasis's Avatar
oasis oasis is offline
I would make the hole being used at the 12 O'Clock position.
(2004-2008): 1971 1302 w/2056
Old June 20th 2007, 22:04
vujade's Avatar
that sounds about right
WinterJam 2010
