9 inch rears it will wheely and burn out if you dont use progreesive power and just dump the clutch..
steve C.. i am surrently using a 210mm clutch with a pressure plate that offers 0.92 pounds per square inch and have a feeling this might be insufficient.. either that or i have a slight oil leak in the system that is causing the slip..!!?!? but i may convert to a kennedy clutch set up or maybe a solid centre clutch disc.. to be confirmed.. |
