  #18
Old January 3rd 2003, 09:11
17x8 will be tight to too big in the back as well. i am running 17x8.5ET55 in the back of my '73 standard (1300). given that is 12mm or 1/2" more offset (wheel moving inboard), but i have 3" wider fenders and have to run a 2" spacer. my rim sits right inside the fender lip and the tire is about 10 mm from the bump stop.
richie, search around gl.com too for more info. there is a lot of fitment info already out there. but you might be able to fit those if you grind the bump stop down and you may have to run a small spacer. but i would be concerned about the outboard side. vujade just mounted 7's (i think ET48) all the way around on his 1302 and they are a perfect fit. see the tech articles.
