Go Back   GermanLook Forums > General > Members Rides
Old September 10th 2007, 11:04
aartjan's Avatar
aartjan aartjan is offline
I've done several buildup things, last month!
People do like pictures, so here we go:
The little sidepanels and backpanel are removable:
The body back on the chassis:
Bottom-view:
Replaced the standard camberadjusters with some larger ones:
New rear-tires and cupstrebe installed:
Wiring:
Current result:
Old September 10th 2007, 11:09
aartjan's Avatar
I placed some 10mm spacers at the front, in order to achieve factory scub-radius again. Scrub-radius also named kingpin-offset is responsible for the self-aligning of the steeringwheel and the feeling (of loosing traction) in your steeringwheel. Without the spacers the scrub-radius would be near zero/neutral, something you don't want with a Germanstyle car!
Some explaination: scrub-radius is 'A':
Old February 10th 2008, 12:39
roadracer
ride height
how much have you lowered the ride height.
cars is beutifull great work
Old February 10th 2008, 12:57
aartjan's Avatar
Thanks! But I really don't know how much the car is lowered, because it's build with parts from several cars. So I haven't got a reference.
However, I noted that this thread isn't updated anymore, so here are some new pictures from (more than) a month ago.
LED turnsignals, behind the horngrills and 911 lenses:
914 gauges, painted and chromed (steeringwheel is temporary):
Ahnendorp Road Racing exhaust (little bit too large for the current 1600, but suitable for future plans):
Current result:
Old February 11th 2008, 16:43
Just beautiful, great work!
Old July 31st 2008, 17:52
aartjan's Avatar
Almost ready! Trying to bring her to a local trackday at Zandvoort.
Some pictures.
In the weeds..
Old August 1st 2008, 06:03
Gorgeous!
Hope you get her all together for the event.
Old May 11th 2009, 21:00
itHaKa itHaKa is offline
hello, i have a similar setup, porsche 17 rims, and porsche 914 speedo, just wanted to ask you if the speedo readings are accurate, since mine reads 10 kilometers higher than real, i have 17 inch rims x 45 tire
thanks
Old August 20th 2009, 19:39
ferfre007's Avatar
ferfre007 ferfre007 is offline
Hermoso!! Felicidades!!
vw standar 1973
vw 1303 sunroof - Automatic Stick Shift 1974
vw variant squareback 1968
VW PARAGUAY
