Old September 19th 2007, 12:51
oasis's Avatar
oasis oasis is offline
If you have a real wide bottom, they may be a tad narrow. If you are weight-conscious about the car, there are lighter options. For my purposes, I couldn't be more pleased. I'll see if I can dig up a picture of mine for you to see.
I found a couple at a site I still frequent.
The first one shows the seats with the CSP shifter. I was told I was going to have interference in 2nd and 4th gears. That information was wrong. Even when my 5'2" daughter slides forward so a friend can have leg room in the back, I can attain 4th gear with no problems. Oh, and you can see the door card, too.
Oops. This was an older picture with the stock shifter after all. There was no interference with it either.
This one shows a little of the rear seat (which was reupholstered) and the speaker shelf. It also shows the missing window vents unfortunately.
(2004-2008): 1971 1302 w/2056
Old September 19th 2007, 13:41
Eatoniashoprat's Avatar
Looks sweet Oasis, Did the speaker sheft come with holes in it? or can you cut your own?
I'm about 5'8" and a 30" inch waist, so I don't think I'll have a problem fitting into these seats.
1302 EJ20 turbo
Old September 24th 2007, 11:00
oasis's Avatar
You cut what you need for the speakers.
