Old October 13th 2007, 10:28
Panelfantastic's Avatar
What is the common way to hook up the thermoswitch for the radiator fans? I'm thinking at the inlet of the engine, so regardless, the fans are operating to keep the entering water at the right temp. I'll be able to set the fan start temp for whatever I want, so that's not really an issue. Jason
On the Eco, the switch was just prior the t-stat. What is the factory location? One caution, up high is good but not so high that if it ran a little low of coolant, you wouldnt know it was cooking. I went through a whole air pocket headache with mine in the factory spot because it was impossible to get bled past the t-stat.
If you havent already, look into the variable fan controllers. They usually include sender and ey'ting you need. What I thought was the shizz is the soft start and faster as you need it function. I never got around to upgrading to one. When my fans kicked on, it put a serious hurt on the electrics and made the Eco skip a beat. The soft start takes care of that.
Keep plugging away! I have to live vicariously through your project for the time being.
Jeff-
No current VW projects
54 Chevy wagon LS2 AWD
56 Chevy Panel "Lost Cause"
VKG Bastage child
