Ryan
If you are down for a little cutting and welding, Pantswagen has put the alloy arms in his bus by using the whole 944 torsion assembly: http://www.thesamba.com/vw/classifie....php?id=507210 |
Does anyone have any how, to docs on this? |
hello
-your 64 will have the inner strengthening do-nuts on the inner parts of the torsion housing to chassis -these are not welded inside-ie the chassis to tube -so -pull out the stock bars -witha recip saw greased up -slice throug the torsion housing athe the outer chassis -on the inner cut through the wld -the half way through the hole in the chassis cut horisontal a few inchs over -cut down at an angle to the width of the tube at the 944's inner pivotts - measure the width of the frame horns of the split -cut a line off the pivots -drill holes in horns to remove bolts cut split torsion off frame horns -cut split shock mount off cut off 944 arcing body mount drill and tap 944 hoousing for trans mount -cut off roll bar mount-it will be whaere chassis is -wed in 944 torsion -insert worn blades and tack th dove tail in note - don't even bother spinning the spring plates -leave it stock - its perfect - now you will 'HAVE' to get 85.5 hubs and the 29 discs - 4 pots -you dont need the stub axles-they are the same you will need to fabricate new shock mounts -BUT as you have narrowed the springplate locals -the shock mounts to the inner chassis now anyway!!! -fit trekker cups -54cm is the driveshaft length -the t25 vanagon has these stock use the sheaths from the 944 -simplypull the torsion end off with pliers - cut sheath down -the end fits the splitty chasss after all that though -you can only fit ONE wheel -and its 16 inch 993 wheel - et70 -or a 17 inch cup 2 9j 70et -you can run a 255 tyrs though - they still just fit against the springplate
http://img.photobucket.com/albums/v2...g?t=1199679209
you actually narrow the springplate width 28mm per side -ie they become bhu width http://img.photobucket.com/albums/v2...g?t=1199679289 shocks inside rear roll bar can b used still
http://img.photobucket.com/albums/v2...g?t=1199679359
just do it if you have the torsion housing -do not take the springplates off the inner chassis will leave you a nice clean hole to line up -you won't even have to get it re aligned -the alloy arms have built in lowering -you cant turn them anyway -as if you do run a ten inch tyre -IT WON'T SIT FLAT
