Old November 2nd 2007, 15:15
fuzzybear1981 fuzzybear1981 is offline
944 suspension
Hi, i have posted a thread under the brake section aswell. I am looking to uprate my 1303 brake system with a 944 2.5l system. i have been told that the reartrailing arms from a 944 may be the same size as my bug therefore allowing me to change the whole back end and not mix and match parts. Also will the front struts of a 944 bolt on a 1303 allowing me to change he anti roll bar to a porsche one and just bolt the lower arm to the ball joint? Cheers Dan
Old November 2nd 2007, 15:47
Turbo Haraune2's Avatar
Turbo Haraune2 Turbo Haraune2 is offline
The early style 944 alu arms wil bolt on to your rear with no modification.
I think pre 1987 cars
Driveshafts require mod to gearbox. new output flanges
Old November 2nd 2007, 16:20
split_trix split_trix is offline
The early 944 steel arms are vertically identical to the 03's so are interchangable.... but the CV's are of a different size diameter and thickness.
944 CV's are same diameter as type 2's but are slightly (4mm) thicker.
If your using a type 1 box you need to change the output flanges for trekker items
All alloy arms widden the track of the vehicle over standard by varying amounts depending on year.... later wider, earlier narrower
hope this helps
chris
Old November 2nd 2007, 16:23
DORIGTT's Avatar
DORIGTT DORIGTT is offline
I just put 944 alloy arms on my Ghia pan and the one modification that has to be done is the replacement of the bushing that the attachment bolt feeds through. The VW bolt has a larger shaft than the 944 bushing which means you buy a polyurethane 3 piece bushing set and install it. Pretty painless to do. You just use a big screwdriver to pry off the metal 'caps' off the std 944 bushings and you'll see that it all comes apart nicely.
Old November 2nd 2007, 16:36
Weren't there soem one year early ally arms that bolted on with no track increase? Anybody know if they used longer axles?
Old November 2nd 2007, 18:56
DORIGTT's Avatar
The pre-86 N/A 924's (non-turbo) & pre 85.5 944's used the steel arms (I'm told)
Old November 2nd 2007, 19:08
yetibone's Avatar
yetibone yetibone is offline
'86 951 alloy arms were the narrow ones, but they will increase the track by 3 inches. The '87 and up 951, and 944S arms will skate it out a total of 6 inches.
In either style of 951 alloy arms, you'll need '87 and up 944S axles so you'll have the correct length to reach the stub axles on the alloy arms, and the proper spline pattern to use Type I CVs on the transaxle, and 944 CVs on the stub axles.
The 951 axles have a coarse spline pattern not compatible with Type I CVs, and '86 and earlier 944 axles for cars equipped with steel trailing arms aren't long enough.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old November 2nd 2007, 21:25
I fitted steel 944 arms to my daily driver 1303, they give about 25 mm per side track increase (wheel bolt to wheel bolt face). As the car has low power output I just used the stock bug axles so the CVs all hooked up as normal.
I cant remember the exact info about a 944 stuff on the front but the info is here, just let your fingers do the walking.
Old November 3rd 2007, 06:55
Thanks but wat about the fronts??
Old November 3rd 2007, 07:44
Cohibra45's Avatar
Cohibra45 Cohibra45 is offline
fuzzybear,
Read Lanners information about what you can and can't do with the mounting of front end suspension of a 944 to the 1303 here:
http://www.vdubengineering.com/techn...onversions.htm
If you scroll down you can read about mounting Porsche brakes (and suspension) on the front of your 1303.
Take care and God Bless,
Kelly (Cohibra45)
Old November 7th 2007, 02:55
Bruce2 Bruce2 is offline
That increase in track is totally due to the 944 brakes. The steel 944 TAs have exactly the same dimensions as a stock Bug IRS TA.
Old November 7th 2007, 07:52
Hi Bruce
Your absolutely correct, I should have made it more clear, but he was asking advice about fitting Porsche brakes.
