Old December 13th 2007, 23:56
Scotts73SB's Avatar
Wow that does fit nice!! Nice job!
Old December 14th 2007, 06:29
T151 T151 is offline
think I lowered the back by a spline or so though...
Old December 14th 2007, 13:54
aartjan's Avatar
aartjan aartjan is offline
Originally Posted by freshprince View Post
How hard are they to fit under the arches? And how low will I be able to go with them?
they are 205/50/ZR17 tyre sizes on atm??
all help gratefully received....
asap. cheers
also any pics of the same would be great
Stock fenders and 7" ET55 with 195/45/17 and 10mm spacers @ front and 8.5" ET50 with 215/45/17 and 20mm spacers @ rear do fit with stock brakes and IRS arms.
The front 10mm spacers are needed to get back (stock) positive scrub radius (without is neutral) and acceptable turncircle. The rear 20mm spacers are needed for clearance between tire and springplate.
You can use the Wheel Offset Calculator to compare various situations. Very usefull!
