the basic thing that a dump or Blow Of Valve does is to get rid of the inlet charged (boost) that is present between the compressor and the butterfly/ies.
it works only when u suddenly close the throttle, cos then the butterflies will close resulting in a higher pressure on this part of the plumbing that results in slowing down the turbo. Basic rule of physics: everything that goes in has to come out. since it cant come out it will not get in, in the first place. IMO running without a BOV will result in increased turbo lag. i would "justify" not using one if your turbo is really small, that stays in boost or really close when u shut the throttle. but what is the point of running a really small turbo? u will get poor performance due to extremely high temps .dont forget that the engine is basically an air pump... Chris
Aircooled 4ever 1973 1303 going towards GL Last edited by beetle1303; November 22nd 2007 at 23:20. |
