  #17
Old December 10th 2007, 19:53
Trogdor's Avatar
Trogdor Trogdor is offline
Originally Posted by Cohibra45 View Post
That's ok Trogdor. It really doesn't matter that much. I can see that you will have major rubbing issues already when you get that thing on the road. The rear tires protrude outside the finder lips and when they bounce, if you run any rear suspension, you will rub!!! The turning radius on the fronts will do the same.
I'm glad to see that you have proved that you/anyone can mount large rims/tires on a static car. The proof will be when you drive it !!!
Take care and good luck ,
Kelly (Cohibra45)
Oh .... did they rub on your car when you mounted them? Because if I can get some advice from someone with firsthand experience that would be awsome.
My button
