Old January 26th 2008, 15:56
yetibone's Avatar
yetibone yetibone is offline
I used one '77 Transporter tie rod to make the lengths correct on my 1303.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old January 26th 2008, 17:56
super vw super vw is offline
Nice, the late R&P super beetle tie rods are about 2" longer than the earlier setup if I remember right.
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old January 29th 2008, 09:21
punchbuggyracer's Avatar
punchbuggyracer punchbuggyracer is offline
I had no intention of bending the tie rod. I had heard that the spindle arms needed to be bent to the same angle as the 1303 to improve the ackerman angle, which I'm led to believe makes the steering more responsive.
Thanks 2443TT but I dont know that I can make the car 100mm wider per side.
Old January 29th 2008, 10:06
That would be weird as the spindle material is cast iron. Bending this is a no-no with regard to safety afaik.
More commonly practice is to reverse mount the steering joint to get a better (ie less) angle. The spindle needs to be machined for this.
Maybe this was meant?
Old January 31st 2008, 07:01
You mean like a flip it kit? I have one to fit to it from vdubengineering.
