Old April 8th 2008, 19:25
jakriz jakriz is offline
Advice from Experience?
Originally Posted by Oval View Post
After being involved in an EJ20T (Subaru WRX) transplant into a Type 3, '73 Notch's 'KISS' advice is teh best words of wisdom of this whole thread
Stock engine
stock turbo
stock management system (with wiring modified to suit VW) and DO NOT turn up the boost
Stock exhaust (as far as practical)
DO NOT allow yourself to be talked into/sold super-hottie turbos and aftermarket management systems and all the rice-racer ********e. It all increases cost and complexity for no real gain on the street. The factory 160kW (220hp) is more than enough to make you grin
Oh, and you better get to know a gearbox mechanic...
That is excellent advice Glen. But are u able to tell me why the conversion u were involved with has had an aftermarket ecu now for over a year as the stock management system with wiring to suit the vw was uanble to work reliably?
I'm surprised the owner isn't bald from tearing his hair out.
Eventually the owner had an aftermarket ecu installed, tuned (240hp@ the wheels on only 13 pounds boost) & has been running since.
Incidently it's the same aftermarket ecu that I'm using http://www.microtech-efi.com/ mine was installed in October 2004, it spent a whole 2 hours on the dyno & hasn't been touched since. 89'000klms (55'300mls) later & it's still going. Daily driven & flogged on the track, over 200hp @ the wheels on only 8 pounds boost, 38+ mpg.
Did I just get lucky with an aftermarket ECU?
Maltese Falcon Racing
http://www.superbeetlesonly.com/foru...y&cmd=sc&cat=6
