Hi there,
Forgive me if I ask the obvious... But how are you going to fill up the radiator if the cap is going to be so close to the (top) body? Or are you going to make a trap-door?
Zeroaxe |
I will use a remote reservoir and have the local radiator wizards modify the top of the radiator if necessary to put a bleeder valve on each radiators to facilitate getting the air bubbles out if in the end the radiators are the highest point in the cooling system.
I am using the Evans coolant system which is a zero pressure system so I'm not to concerned about the pressure caps and what not. I was planning to fill the coolant system with this system.. |
