Old November 25th 2008, 03:44
fastbacker fastbacker is offline
bug@5speed parts
Is their nosecone needed for 912 901 (as opposed to 914 901) install? If so, why?
Thanks-
Craig Backer
Old November 26th 2008, 03:27
Craig,
don´t know if I understand right, but I explain what I understand the problem is:
912 and old 901 (aluminium cases) have a different position of the upper pivot (hope correct word) than the later 901, 911/01 and 914 gearboxes. That´s the only difference (besides change from aluminium to magnesium) between the nosecones (914 is quite different, but not in positions).
Martin
Bug @ 5-Speed
Old November 26th 2008, 03:36
So, is it essential I purchase your nose cone to install my aluminum case 912 into my 69 bug?
This is what I was asking knowing the 914 nose cone has to be swapped.
Thanks-
CB
Old November 28th 2008, 08:51
Craig,
my nosecones are about 30 mm shorter than the original ones. If you give up 30 mm in the Beetle to istall a gearbox there´s not enough space left for a normal installation of the engine. With my nosecone the gearbox is positioned just as the type 1 gearbox (measured at the bellhousing).
Martin
Bug @ 5-Speed
Old November 28th 2008, 14:59
Bug@5speed(US)'s Avatar
Fastback,
I will send you the pdf that I promised. It was good conversing on the phone, hopefully I answered all your info.
I see Martin, provided you the other bit of info I was going to send you..
I will send you the prices shortly.
VR
Alex Olaverri
Email: Bugat5speed@yahoo.com
Tele: 973 204-5463
