Old April 16th 2009, 22:55
jmd's Avatar
jmd jmd is offline
starter motor.
I am using the stock porsche 901 starter motor on a 5spd. This will run into an STI engine via kennedy adapter bits. I just got my fresh trans back and have the following part number on the starter: Bosch 0-001-212-002 EB-> 12V .08PS
hope that helps...
I have a link to a local porsche race house that specializes in the older 911 cars if you need a line a verified parts...
keep us posted.
Old April 19th 2009, 06:31
buggyboyshane buggyboyshane is offline
hey chug- a- bug, what did you do starter wise?
i have a reconditioned 1600 type 1 (actually got out of a bay, but is type 1) theres no starter in the project, which one do i need to work well? i remember someone telling me a bug one would work but you had to machine into the gearbox casing slightly to allow the starter to go in more. do i use a porsche starter or bug starter, preferably bug, as i can get my hands on one no probs.
cheers jmd, i just wonder what the difference will be as im running just a stock bug motor, but ill deffo give you a shout if i need parts, cheers guys...
Old April 19th 2009, 09:44
I think I remember reading that the autostick VW and the 914 starter had the same part numbers and will work with the 200mm type 1 flyeheel.
