Pete, I was thinking of using the atv stand to remove the engine and tranny as an assembly rather than one at a time. It could make life simpler when I need to pull them out of the race car for re-work.
I'm sure you could.
You've made the rear apron removable, so it should slide right out as one assembly.
'72 super '65 bus '52 split |
Didn't want to modify the dash for gauges. Bought a multifunction gauge to mount at the steering column with a Motometer holder. The gauge holder broke when i put the gauge in.
So made a aluminum ring and bolted it to the Motometer center section. Need to polish it up now.![]() ![]() gauge: ![]() "The E-3 can measure up to 4 EGT/CHT channels, a RPM input, a universal temperature sender input and a universal pressure sender input with a user programmable low/high alarm limits." Need to wire up the motor and run a multiconductor cable to the steering column. Pete
Got a set of BBS LM's out of Miami, last year. Found out they wouldn't fit without some thinking. The Remmelle hardware was hitting the inside of the wheel, so the wheel couldn't be bolted up. I was determined to make it work. Decided to try and make my own setup to allow clearance for the deep(ET65) rim/tire. I'm just finishing them up now, almost a year after starting them.
![]() ![]() ![]() Should i narrow up that springplate some more? Need to do get them welded and coated. Thinking silver anodize/powdercoat. Local shops? ![]() Sooooo the 18x10 LM's will now fit. It's a very tight squeeze that will need some grinding of that 1 bolt. ![]() ![]() Will the sidewinder exhaust fit on the inside of that tire? Who knows...... We'll see......... I can't get the front wheels on. The LM's have a slightly smaller lug hole than the Dyno's. The Dyno's have always been a bitch to pull on/off. The studs look a little off. Could be bent? or not seated properly. Guess i will have to pull off the front brakes, AGAIN, and get new studs. Or drill the LM holes the same size as the Dyno's. Pic below has the wheel just barely on the studs. Couldn't push it on. ![]() ![]() Lanner from Vdub Engineering fixed the front hubs to get the spindle nut sitting flush. This is how they were. Didn't like that at all. ![]() Pete
'72 super '65 bus '52 split Last edited by petevw; May 7th 2009 at 02:27. |
The 'whacking' to drive the studs all the way to properly seat and be perfectly perpendicular is is scaringly great (ask me how I know...), so I can imagine this could be the (simple) cause. |
Pete,
That bottom coilover bolt looks a tad long. There will be a substantial bending moment on the end of it particularly as you are exclusively using the coilover rather than torsion bars. Is there a clearance problem with the damper body on the alloy arm? Clive |
Pete your car is looking nice!
I like what you did with the oil cooler, are you going to go dry sump?
GL ghia restoration: http://s473.photobucket.com/albums/r...20restoration/ __________________________________________ |
The project looks awesome Pete ! I can't wait to see you driving that beast.
Sandeep |
