Old June 23rd 2009, 14:22
tom'72's Avatar
tom'72 tom'72 is offline
Weekend racer/ dragster project.
A small introduction on my project which has been in the making for about 3 years now in total.
Started with a Standard bug with a 1600cc engine, engine blew up and I wanted something a bit beefier.
Bought a JDM EJ20TT engine with a Kennedy adaptor kit, flywheel and clutch
And a shortened sump from bug@5speed in Germany
To get the engine to fit inside the body it had to be moved forward so I had to go IRS
(notice the fantastic yellow paint and the 944 brakes which I later ditched)
Old June 23rd 2009, 14:30
tom'72's Avatar
Engine mated to the Pro street IRS tranny ( will swap for a G50 one day but not soon)
Käfer Cup Brace installed and put 18" BBS Le Mans (polished) on.
got a new front beam from CSP with adjusters welded in and reinforced it with these stainless steal parts, Red Koni shocks were also installed.
Old June 23rd 2009, 14:38
tom'72's Avatar
Swapped the 944 brakes for a 996 GT3RS setup
Also fitted a uniball setup in combination with adjustable AVO coilovers
Relocated the battery and put in a larger fuel tank with a return fule line
Old June 23rd 2009, 14:49
tom'72's Avatar
On to the body mods:
Cut out the rear 1/4 to fit air scoops that feed the IC
cleaned it all up a bit, some welding was required
Also fitted a ragtop kit for those summer drives
Old June 23rd 2009, 14:53
tom'72's Avatar
Interior mods so far:
sparco seats
Old June 23rd 2009, 14:56
tom'72's Avatar
This is how far I am right now, shell is painted
Will post pics of the the build up of the car soon.
Old June 23rd 2009, 15:38
All I can say is: WOW!
Amazing clean build! Very well done. Love to see the intercooler location and the connection from the scoop towards it/them
Old June 23rd 2009, 16:26
Humble's Avatar
Humble Humble is offline
very well done! I can't wait to see this thing come together! Where did you mount the radiator? The dash looks very clean I dig the look of the blacked out gauges. The only thing you might regret is that steering wheel, it's gonna get mighty hot in the sun
Old June 23rd 2009, 19:18
Tom you sneaky devil!!! All of this has been going on right under our noses and you didn't even give us a sneak peek!!!
Glad you finally filled is in, looks like it's going to be an awful lot of fun to play with. Are you sticking with the TT setup or are you going to convert to a single turbo? I too can't wait to see your intercooler setup, I'm just getting mine up to snuff now.
Old June 23rd 2009, 21:46
Nice project. Bet you can't wait to get it on the road.
Old June 23rd 2009, 22:42
Great work so far! Get that project done, and post some video.
Old June 24th 2009, 04:49
evilC's Avatar
evilC evilC is offline
Great build up and high quality work.
(A point of caution though - the stainless steel beam braces will be subject to cyclic load, which stainless is not suited to as it fatigues quickly. I see that the mounting bolt is stainless also. The whole thing looks well engineered but it would be worthwhile keeping an eye on the chassis end as part of your general maintenance regime. Failure of that part should not be catastrophic as presumably the beam is still held with the standard bolting arrangement)
Old June 24th 2009, 05:11
Jim's Avatar
Jim Jim is offline
Very very good and clean job!!
With this engine in the back it might be kick some as...s in the road!!
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old June 24th 2009, 12:49
tom'72's Avatar
Thanks for the compliments but I couldn't have done it without wisdom and experience of the members on this site.
Made 2 strong brackets that are bolted on the front beam with the standard chassis bolts.
some pics:
Made an aluminium schroud for the rad and an air ducts under de front that's powered by a linear actuator ( when the car will be standing still and the air ducts is closed it will be tucked away behind the front apron).
Old June 24th 2009, 14:31
Xellex's Avatar
Xellex Xellex is offline
wow verry nice build! The only thing I don't like is that steering wheel
www.vw1303s.com
