Old September 5th 2009, 11:23
spooky spooky is offline
944 rear brakes on oval: help
Hi guys,
Finally getting round to rear 944 brake conversion on my oval.
Everything seemed to be going okay, but when i put the rotor on i found that it didn't quite clear the caliper mount etc properly. Any ideas? Any help would be greatly appreciated!
Below are some photos:
Standard spacer:
bolted up:
rotor doesn;t clear:
Old September 5th 2009, 14:08
Never mind the rotor. I would be worried about the caliper mounts spooky!
Old September 5th 2009, 22:18
STIDUB STIDUB is offline
im with him ^^ i havent seen the 944 setups up close but thats somewhat concerning with the welds & that extra bit hitting the rotor, id suggest taking that part, or the whole kit back to where it came from & ask for an explaination why its like that, thats assuming the backing plate/caliper bracket is/was a factory made part?
1971 Superbeetle, stripping the old stuff, getting ready for paint, then bolting on all my goodies, sorting problems by ones self is a challenge it seems, any GL beetle people in Brisbane say hi!
Its been 3yrs since i drove my dub
Old September 6th 2009, 02:49
I agree that all looks very different to any 944 brake setup Ive seen before.
Below is a 944 backing plate from and old car of mine, ignore the middle section, I had it altered to narrow my track.
Old September 7th 2009, 05:23
evilC's Avatar
evilC evilC is offline
Hi, Apart from what has already been said, I note the rotors are cross drilled, are they turbo rotors, which are thicker than standard 944 ones. That caliper mount does look flimsy!
Old September 7th 2009, 06:53
Hi guys, thanks for the replies. The calliper mounts have been extended (not by me) for using a different calliper.
The machining of the backing plate i guess is not correct such that they do not sit far enough back.
Old September 7th 2009, 06:56
the extra bit is the standard calliper mount. cylindrical extensions have been added (again, not by me) for non-standard calliper use.
Old September 7th 2009, 22:51
If the extensions are just spacers they should not be threaded. If they are threaded then make sure the bolts you use go all the way into the original mounting holes. That would help some, but still not the safest.
Tags
944 oval rear brakes
