Old January 26th 2003, 19:18
vujade's Avatar
vujade vujade is offline
Martice
those spoilers are looking good
WinterJam 2010
Old January 26th 2003, 20:00
Martice's Avatar
Martice Martice is offline
Hi,
I am working on a deal for shipping at the post office right now.I may get shipping for a spoiler at around $20-$30(USD), insured, by airmail, 7-14 days...This week I'll tell you for sure.
I'll post tomorrow all the mounting instructions, its really easy, you'll see.
later,
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old January 26th 2003, 20:03
Martice's Avatar
Originally posted by vujade
Martice
Thanks vujade!
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
super vw super vw is offline
thanks Martice!
Old January 26th 2003, 21:41
vujade's Avatar
Martice are those for Supers or Standard beetles?
Or do you have different ones for each?
WinterJam 2010
Old January 27th 2003, 02:43
i heart vw i heart vw is offline
Question...you said that they mount like the Kamei ones but those of us (or just me) that don't know how that mounts...how does it mount?...and would it fit my 74 super?...can't wait to get one!...tim
saddly my 74 super has to go ...
Old January 27th 2003, 05:41
Martice's Avatar
Thumbs up Mounting instructions
Hello,
This are the mounting instructions for super beetles- 1302 and 1303.
(I will try to supply all the mounting parts and mounting instructions for with each spoiler)
Mounting parts:
2 bolts M 5 X 20 mm with permanently attached washer
2 washers 5.3mm
2 lock washers 5.3mm
2 nuts M 5
4 rubber discs 5 X 20 mm, 5 mm thick.
Mounting:
Spoiler fits vehicles produced up to 7/74 and after 8/74.Use outer holes for vehicles produced up to 7/74- inner holes for vehicles produced after 8/74.Production tolerances may make it necessary to file out the holes.
1.Attach spoiler using bumper bolts. Spoiler is positioned in the bumper, between the bumper and mounts on 1303 produced after 8/74.
2.Drill through holes present in spoiler into the lower edge of the fenders using a 5.5mm dia. bit. Align if required.
3.Attach spoiler to fender with bolts-washers and lock washers, and nuts from rear. Position rubber discs between fender and spoiler.Use 1 or 2 discs as required for adaptation.
I hope it helps!
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old January 27th 2003, 05:48
Martice's Avatar
only for Super beetles.
Yes, the spoilers are only for Supers-1302 and 1303.
I have tryed to make one adapt(with fiberglass work) on a Standard beetle but its very very tight.I don't think it will work.
It was very hard to make this Super beetle spoiler straight, with a good mold...
later,
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old January 27th 2003, 06:32
Tim Tim is offline
Hi Martice,
Lighter the better with the decklid, I guess something less than 3kg will be good. Under 2kg will be even better. 1kg would be perfect but probably impossible.
The strength of the decklid is not a concern as long as it's got the shape of the late model with vents to allow more cooling air to the engine (no license plate light housing of course).
I think a single layer of fibre will be good enough. I will mount it to the body with hood pins. So, reinforce section for hinges is not necessary, I suppose.
Would it be difficult to make something like that?
Tim
Old January 27th 2003, 09:41
vujade's Avatar
I am also interested in a lighter decklid.
I do not want any vents in it though.
WinterJam 2010
Old January 27th 2003, 18:51
Martice's Avatar
I belive it can be done under 3Kg, probablly at around 2Kg.
The problem is the stock vents...I can make it without the vents, with some custom vents maybe(thats for you Tim)Do you really need the stock vents?
It should be strong anyway.
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old January 28th 2003, 01:27
Tim Tim is offline
It's great that you can make a light version decklid. With or without vents is not a big issue. I actually like more the smooth look without the vents but vents are just functional for racing. If it can save you from extra work (hence extra cost to me maybe), I will be happy to have it without the vents. I can make some cutouts myself at the license plate area if necessary.
I will buy more than one (maybe two or three, for spares in case of damaged during racing) depending on the costs and whether you are willing to make more. When you are ready with the price, please let me know.
Tim
Old January 29th 2003, 09:31
Martice's Avatar
pics
lightning bug,
I've took some pics of the spoiler mouned on the car today.Check them out!
PS:Please excuse the ugly rusted bumper...
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old January 29th 2003, 09:37
Martice's Avatar
pic2
the pics are not so good but I could not move the car outside because the shifter and all are out and it is in gear...+it is raining..:silly:
If you have any other questions please ask!
regards,
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
Old January 29th 2003, 09:48
Martice's Avatar
Post vujade and Tim,
Tim,
I understand that you want the decklid without the mounting sistem(that is on the back).
Vujade,
How would you like it, with or without the sistem?
(with the sistem will be more expensive and more heavy)
Let me know so I can estimate a price!
E-mail Martin
'71 1302S GL
'69 1300
'61 1200
