Old October 19th 2009, 04:33
70Turbobug´s 2 liter turbo
Hi everybody,
I´d like to share my turbo project here aswell.Of course it´s a german looker!
Here are the engine specs:
94x71 - stock crank and stock cylinders - for now.
webcam 86a - out of the box with the 108° LC
straight cut cam gears
Jake Raby parkerized lifters
Cromoly pushrods
CR 8:1
stock CU Bus pistons
oil squirters for the pistons
stock rods balanced with Raceware bolts
cryoed and coated KS main bearings and cam bearings.
Six 13H7 Remmele through bolts
Raceware headstuds
1.7 heads ported 41x35 valves exh.valves are sodium filled,Remmele Dual springs
Autocraft 2 stage dry sump pump
200mm 3.9kg flywheel - clutch TBD either Remmele (Sachs) dual disc or KEP dual disc.
Remmele CF fanhousing 10 blade 911 fan
four 45mm Throttlebodies from a BMW 1150GS Motorcycle - all cable operated,no linkage
4 550cc(@3 bar) siemens/Bosch Injectors
Bosch LSU 4.2 wideband lambda
Bosch narrowband lambda
MFT EGT sensor
Bosch IAT sensor
Bosch COP igntion modules
Ebel-Tec ECU w/boost control
Walbro inline pump
GT3071R .63 A/R turbine .50 A/R compressor
Tial 38mm WG
Greddy Blow off
liquid-Air intercooler
The car:
´84 mex body on a ´70 automatic pan
944 turbo aluminum trailing arms
Remmele uni-ball coil over rear suspension
4 piston boxster calipers + discs rear,911 carrera 4 piston calipers and discs in front
Remmele uni-ball coil over suspension in front
Heigo aluminum rollcage
091 gearbox
944 turbo axles and cv joints
17" cup 1 wheels 205/40/17 + 245/40/17
here are some pics,more to follow
