Old April 9th 2008, 19:24
gonebuggy's Avatar
Me: for all of you custom, machining needs. Prototyping and small production work. I can open up your cylinder heads/flycut, open up the bores in cases. My rates are about HALF of what you'd expect elsewhere.....
Drop me a line!
1970 Bug
2110cc. ???Whp, ???Ft/Lbs
Old June 2nd 2009, 18:32
petevw's Avatar
petevw petevw is offline
Alex made a couple pieces for me, and they turned out great.
Local Anodizing shop:
Brimac Anodizing
542 Kipling Avenue,
Toronto, Ontario
M8Z 5E3
TELEPHONE: (416) 255-4411
FAX: (416) 255-3145
Was very happy with their anodizing work. Great service and price.
I'm looking for a Powdercoater......... Anyone know of any?
'72 super
'65 bus
'52 split
Old June 2nd 2009, 20:10
gonebuggy's Avatar
Thanks for the kind words Pete!
Try these guys for Powdercoating:
http://www.yellowpages.ca/bus/Ontari...&le=c53523c1ba
I got all my engine tin done by them a few years ago, very good product with fast turn around and good rates.
1970 Bug
Old June 8th 2009, 09:23
germansupply germansupply is offline
alex has done some machining for us also. fair price and fast turnaround.
as for brimac anodizing, i used to manufacture furniture, this is going back into the late 80's, and we used brimac then. their work was perfect, and it's good to see they're still in business.
Scott Lyons
http://www.germansupply.com
Old November 6th 2009, 19:08
petevw's Avatar
Need to strip these crotch cooler flaps.
Have you guys used any media blasters around here? Wouldn't sandblasting pit the crap out of them?
'72 super
'65 bus
'52 split
Old November 6th 2009, 20:09
gonebuggy's Avatar
Pete,
Glass bead at 40psi. My cabinet is currently not setup/opperational
Fishburn and Proctor on Steeles are your guys to see.
1970 Bug
Old November 6th 2009, 20:28
petevw's Avatar
Thanks Alex,
Looked them up:
Fishburn Proctor Sandblasting & Painting
15479 Steeles Av E Hornby, L0P 1E0
(905) 878-1843
'72 super
'65 bus
'52 split
Old November 6th 2009, 20:53
gonebuggy's Avatar
That's them!
1970 Bug
Old November 11th 2009, 02:58
Mark the canuck Mark the canuck is offline
Hi,
Although I've officially retired from the resto/engine biz I will still keep my hand in things though.
I can rebuild porsche 901 transmissions for a good price. With parts 3 day turn around. Two cores usually makes one transmission at low cost.
I've built 3 for myself, (technically I have a 914 rebuilt 901 sideshifter in stock) and I'm turning a 911-901 4 speed into a 5 speed right now.
If there's enought interest I'll build some VW trannies for the faithfull, maybe keep a couple in stock.
Any interest?
74 914-6, six conversion in progress. Major progress, twin plug macining done and all the parts coming together for a for a hot street 3.0.
'67 kombi, 2007cc, Summer daily driver.
'67 bug, painted and waiting for assembly, Empi GTV project, 102mm Nickies, 78mm crank, SDS FI, 2.6L T4 monster in the works. Now 98% done, just need to work on the the motorcycle ITB intake.
Old June 5th 2010, 15:42
67ghiaTIV 67ghiaTIV is offline
Fuel Injector rebuilders
My daily driver needs the fuel injectors rebuilt. Any recommendations for the GTA.
Jamie
Old March 15th 2013, 12:28
Good idea Sandeep! I´m not sure if some of my list will help anyone outside of europe that much since freight costs usually kill unless it´s an exclusive part that isn´t offered in the U.S.
Engine 2320ccm TIV turbo:
Assembled by myself - all machine work done by www.remmelemotorsport.com
OEM case modified by www.remmelemotorsport.com
6x 13mm toolsteel through bolts - www.remmelemotorsport.com
Webcam 163 - webcam www.webcamshafts.com
Raceware headstud kit - Raceware http://raceware-fasteners.com/
Manton Pushrods - sourced from www.aircooledtechnology.com
Parkerized TIV mechnaical lifters - www.aircooledtechnology.com
Custom 102mm JE pistons - www.jepistons.com
102mm Deutz BF913 cylinders - www.deutz.com modified by myself and Remmele Motorsport www.remmelemotorsport.com
crank - stock 71mm
rods - stock Raceware bolts,balanced
main,rod and cam (doublethrust steel) bearings - www.aircooledtechnology.com
3.5kg 215mm flywheel - machine and balance work done by www.remmelemotorsport.com
Remmele Version 5 CU heads 47x39 (nimonic) - www.remmelemotorsport.com
Dry Sump Oil Pump - Custom/bespoke from Thorsten Pieper
356 T6 Aluminum Oilcooler adapter - www.remmelemotorsport.com
356 T6 aluminum Oilscreen cover - www.remmelemotorsport.com
CSP 45mm Python Exhaust Header - www.csp-shop.de modified for turbo (yet to be done by myself)
Garrett GT3071R turbo .63/.50 71mm stage 3 wheel 4" inlet - www.atp-turbo.com
Tial wastegate - www.atp-turbo.com
Greddy BOV - www.atp-turbo.com
CFK 911 style fan shroud - www.remmelemotorsport.com
OEM 911 fan ring
911 repro fan - www.vertexauto.com
Autotune.fi ECU (Megasquirt 3.57 ECU) - www.autotune.fi
Black Ops Injectors 1400cc - www.fiveomotorsport.com (currently 550cc Siemens EV14 injectors,too small)
2x 45mm dual throttlebodies - modified BMW GS1150 throtlebodies on bespoke aluminum plates for IDF pattern completely cable operated
CB performance "turbo hats" on bespoke aluminum baseplates
Water/Air Intercooler - Ebay
Chassis & Suspension:
Galvanized 1970 automatic floorpan reinforced with steel tubing and painted with Brantho Korrux 3-1. Brantho Korrux - TBS Aachen Ebay,Germany
Adjustable front beam incl. all new parts - CSP www.csp-shop.de
Porsche 944 S2 Turbo rear aluminum trailing arms - business no longer exists
Porsche 944 rear brake calipers + discs (for now) - from a friend
Porsche 996 Carrera front brake calipers + discs - used from www.remmelemotorsport.com
Brake caliper adapters (front) - www.remmelemotorsport.com
Porsche 944 Turbo master cylinder - Ebay
Complete front and rear Uni-ball suspension system: front Remmele/Koni coilovers, rear Remmele/Bilstein coilovers (this was his first version,now much better/more advanced shocks available)
CSP cup brace - www.csp-shop.de
CSP front beam supports - www.csp-shop.de
17" Porsche Cup 1 wheels (for now) later 19" OZ HLT or Supperleggerra wheels.
Transmission - Rancho Pro Street Plus (coming soon)
Body:
Pre´68 Epoxy front fenders 4cm wider - www.remmelemotorsport.com
Epoxy rear fenders 8cm wider - www.remmelemotorsport.com
Late model rear valance with stanced holes - www.remmelemotorsport.com
carbon fiber running boards - www.remmelemotorsport.com
epoxy front/rear bumpers for widened fenders - www.remmelemotorsport.com
BugTech race shifter black - www.bugtech.de
Speedhut instruments - www.speedhut.com
Heigo rollcage - www.heigo.de
Kerscher bespoke leather bucket seats (Recaro based) www.kerschertuning.de
Paint -code LZ5K santorin blue metallic pearl from Audi
Old March 15th 2013, 12:52
I do still do engine work mostly custom, but I also do stock. Unfortunately if you are looking for cheap I'm not your guy.
My work is top notch, I've been doing a lot of 911 stuff lately.
