Backspacing on a Super
I understand the differences between backspacing and offset. Unfortunately, I do not currently have a 1302 or 1303 yet to do some measuring. I have a potential wheel deal -- which I know is putting the cart in front of the horse, so to speak -- and I'm trying to figure if these wheels are worth getting. (I'm not interested in flipping them on eBay although the thought crossed my mind.)
Does anyone know what the max backspacing (the mounting surface to interior edge measurement of the wheel) there is on a Beetle/Super Beetle for rear wheels? Same question, but for the front wheels of a Super (1302 and/or 1303) while assuming TopLine MaXX struts, Kerscher struts or some other similar struts are being used. From there, I can figure the wheel's width, offset and any spacers (if necessary) that might be needed with each wheel being considered.
(2004-2008): 1971 1302 w/2056 Searching for a new project ... |
standard guards & narrow springs +40 to +50 offsets work on a 7" rim 2" wider i have 8" wide & +6 offset yet to see how much more can be squeezed under the rear but i think my mounting face is further out than stock on the rear now so it wouldnt help
oh, those 7s fit VERY close to the spring around 3mm, slight decrease in steering angle before rubbing the body, the 8s however have about 20-30mm before spring, makes a decent diference to the turning circle id imagine, not sure what stock was like in comparison though, sorry, that may help though
1971 Superbeetle, stripping the old stuff, getting ready for paint, then bolting on all my goodies, sorting problems by ones self is a challenge it seems, any GL beetle people in Brisbane say hi! Its been 3yrs since i drove my dub
There happens to be a 1303 "hot rod" on the Samba in the classified section. It may give a clue to the rear. Thanks.
it also depends whether its a 2 or 3 bolt front end
the 2 bolt front ends have about 15mm per side wider front track ive got 17x7 all round on my bug which has 3 bolt topline front end and et40 rims are a perfect fit ive got rear discs on the back which add about 10mm per side but even before these were on it didnt look any different ![]() but if u had a 2 bolt front end u would need et50-55 on the front
1974 Germanlook 1303 SUBA-beetle Subaru EJ254, BoostR 17", topline suspension, 4 wheel discs and A/C |
correct, same things different names, oh, my wheels, similar to joels, post above this, because i have rear discs sit about 8mm further out each side, & with the same 17x8 et+6 i have about 2" clearance from tyre to spring plate/upper bump stop bit, they should sit just inside the guard, havent had the body on the floorpan to see just yet though but by calculations its pretty close ![]() ![]() ![]() ** note, theres no floor under the body with those shots, thats just loose measuring of where they will sit I have photos of narrow springs with +45s on the strut to compare to the +6's if you like, also think i have comparisons for the rear also
Thanks, both, for the replies. I will see the pics when I get home as my work computer doesn't let me see certain hosting sites. These measurements should help me a lot on deciding on the wheels that are available. They're a bit extreme.
